converting 2 lights and switches to two way | Page 2 | on ElectriciansForums
Discuss converting 2 lights and switches to two way in the Lighting Forum area at ElectriciansForums.net
The forum does not give step by step guidance, #6 gives a general idea of how it should be done. As previously stated this is rudimentary for an electrician and maybe your best course of action if you cannot see how #6 helps is to seek the services of an electrician.
cheers, i hope i can be as helpful to you in the future
Sorry what do you mean by “ remove one of the switch drop cables”?
[automerge]1579373353[/automerge]
Run a 4 core between the two switches and leave the existing 3 core switch wire to what will be the first down light?
You have written in your profile that you are an electrical engineer, but you don't know what a switch drop is, or apparently the difference between 3 core & earth cable and 4 core?
Reply to converting 2 lights and switches to two way in the Lighting Forum area at ElectriciansForums.net
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
Ha.had a whole school corridor like that when I was an apprentice ,was only changing type of fitting .nightmare .couldn't work out why there was...
