Converting 3 gang to dimmable without chasing for bigger back box | Page 2 | on ElectriciansForums
Discuss Converting 3 gang to dimmable without chasing for bigger back box in the UK Electrical Forum area at ElectriciansForums.net
London
Hi all. Just seeing if anyone found manufacturer or a solution to avoid chasing out for bigger back box if converting lights to dimmable or just converting one switch to dimmable as all types found require bigger back box. Have looked into grid switch systems but these still seem to require a double back box? Cheers
Thanks chaps but your all off the mark i might not of made self clear 3 gang dimmers require a double back box am looking for any products or solutions that have 3 dimmers that fit the width of a single back box so can avoid chasing out
Hi - sorry, I’ve not seen 3 switches in a 1g box, but I hadn’t seen Lightwave before ?
[ElectriciansForums.net] Converting 3 gang to dimmable without chasing for bigger back box
Ha, yes I meant dimmer switch. Plain switches are common enough :) .
Reply to Converting 3 gang to dimmable without chasing for bigger back box in the UK Electrical Forum area at ElectriciansForums.net
Good point but then regular plastic switches aren't permanently running a wireless network module inside. It just seems odd not to have an earth...
Ah OK, that makes sense. Thank you Avo.
