Just wanted to pick your brains lads, we have a few boards at work nearly all are 16th MK boards, with split load, usually RCD only on sockets outside/likely to be used outside, rest on mcb's, I am confident the new range of 60898 rcbo's and other gear will drop straight in, it seems just to be a case of running a new Blue N strap to re link the split Neutral bar, and buying a new copper bus bar, can any one see any snags with this at all ? Obviusly it will all be IR'd out first as part or the PIR's.
Thanks Lads
J
Thanks Lads
J
