converting mem board | on ElectriciansForums
Discuss converting mem board in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
i have a board which is protecting one side with 100A main switch, and the other side is being protected by 100A double pole rcd.
can i get another 100A rcd and put in as main switch which will cover the side un protected by rcd.[h=1]MEM/EATON 100Amp 2 Pole A100HE 100 Amp 30mA Double RCCB Breaker 100A RCD/RCBO[/h]
making this board 17th compliant then.
there is plenty of spare ways in this board so if i can get another 100A 30mA main switch and then mem mcbs for the new circuits, seems easiest than changing board ... trev
I doubt it'll be easier than changing the board. You'd have to disconnect the circuits for testing anyway, so all you'll be saving is the time to undo the board itself, and screw on the new one.
i=p/u
There is nothing wrong with this but to be honest change the whole board!
How much are you going to charge for adding a RCD to this board? A fully loaded 10 way only costs £60-£70, this is the cost of a MK RCD before anything!
Again nothing wrong with doing it that way - just remember the sockets will either trip the 1st RCD or the 2nd RCD - no way of telling which it will do first!
i=p/u
Still would not be 17th compliant though.
Dont cut corners - just get yourself a new CU and change the lot.
If your doing it for the customer sell it as:
Same price
Includes a free periodic (EICR)
Includes 6 years work guarantee
well i only need 2 more circuits for new extension, yes trying to save money as i didnt price for removing old cables and tidying up exisiting for new joists . which was a days work with 3pm finish:smile:
i=p/u
ramp and an earth leakage test would give you a clearer picture...
ok extra fire alarms then because of this lack of earthing - lol
Out of interest what sort of work are you doing on this property? its sounding like a rip out and rebuild??? but not a rewire???
Reply to converting mem board in the UK Electrical Forum area at ElectriciansForums.net
BS3871 type 3's have a similar shaped operating curve to BS60898 type C's. Any fault that will meet the disconnection time of 5s (for 63A...
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
