View the thread, titled "converting mem board" which is posted in UK Electrical Forum on Electricians Forums.
i=p/u
i have a board which is protecting one side with 100A main switch, and the other side is being protected by 100A double pole rcd.
can i get another 100A rcd and put in as main switch which will cover the side un protected by rcd.[h=1]MEM/EATON 100Amp 2 Pole A100HE 100 Amp 30mA Double RCCB Breaker 100A RCD/RCBO[/h]
making this board 17th compliant then.
there is plenty of spare ways in this board so if i can get another 100A 30mA main switch and then mem mcbs for the new circuits, seems easiest than changing board ... trev
well i dont think i have ever finished a thread /post how it should be done.
i fitted new board for nearly same price as the rccb/rcbo that i needed to convert the mem board.. few heads is better than one so ty for guiding me to the harder option but better solution.
can i get anyone to confirm what test you carry out before you change a cu. ??? as you know im an apprentice but flying/ploughing on
Reply to the thread, titled "converting mem board" which is posted in UK Electrical Forum on Electricians Forums.
