Converting pendant to downlights... | Page 2 | on ElectriciansForums
Discuss Converting pendant to downlights... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi there, Could i trouble you for which WAGO box you use please as what you have done is the exact job il be doing.
Replacing the original pendant for 4 down lights.
wago lighting box. screwfix.
same as they were 10 years ago when this thread was active.
Reroute the light cable to the first downlight, then loop from there. No need for a WAGO box unless it’s got a pesky looped live at it.
My thought as well. Usually when you have several new spots being fitted it's likely possible that not just the switch wire but also the neutrals can be rerouted to one of the new locations and the existing pendant hole can simply be plastered up. No need for a MF jb.
Reply to Converting pendant to downlights... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you, it is always good to hear another suggestion :)
I'll try one of these maintenance free boxes...
