Cooker and hob advice | Page 2 | on ElectriciansForums
Discuss Cooker and hob advice in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Anyone connecting a future appliance should be verifying that the circuit and connection method are suitable for the appliance.
I totally agree with you but that does not always happen. A new owner who is moving in will most likely disconnect his own electric cooker from his old property see that in his new property there is a cooker isolator in place and rewire his new cooker in to the cooker outlet without giving it another thought.
Correct me if im wrong here please but a dual outlet plate has the feed or supply in and the ability to connect 2 loads out.Your drawing is showing the highest load on the last point of radial which would be fed by 4mm T&E cable from either a socket or FCU. If the dual outlet plate is fitted then there is no issue with the 2x 6mm T&E cable. One 6mm T&E cable will feed the cooker and another 6mm T&E cable will supply the socket or FCU. By using 4mm T&E to supply the cooker outlet you have a chance that in the future the owner or new owner may install an all electric cooker that will be fed by 4mm T&E and could potentially become a weak link when the electric cooker is under full load.
If you are using the dual cooker outlet then yes you can do it this way as you can get 3 6.0mm cables in.I was referring to a standard cooker outlet plate if used.the reason I said 4.0mm was sockets these days do not have the large bellmouth terminals they used to.The post I thought was stating gas hob electric oven aprox 16A.If this is the case we will have to wire 32A radial socket circuits in 6.0mm then in case of full load.
A driver could fail to stop at my nearest zebra crossing tomorrow but I'm not going to the shops in a crash helmet.
this would of only been a link in a dual K.O.box the cable is ratted above the 32A protective device
Will the sso be next to the cooker outlet, if so no problem wiring the spur in 2.5 from a dual outlet plate, just as you would a spurred sso from a final ring circuit with 32A protection. Wiring in 6.00mm for the sake of the ignition is slightly over the top.
Hi bought a new electric cooker and gas hob
Have a 6mm cable with isolator above worktop and a junction box behind cooker
Because the gas hob is only ignition needed for electrics can I just wire it to the 6mm cooker junction box and the isolator will control both
Or do I take it off the ring
Run a 4mm cable from jb to a new socket
Plug the ignition into the socket
Provided it's 32a protecting the circuit
Reply to Cooker and hob advice in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Terminal box on a UK cooker from 50 years ago would easily accomodate a 10mm2 cable, even though 6mm 2 was adequate. Nowadays, most cookers, ovens...
I actually did it with a 4 core 4.0mm swa last week!
