C
Chrisarm5
Hi All
I've recently been doing a kitchen re-wire, everything done, sockets added to ring etc. however for the cooker ive wired a 6mm radial to a cooker switch, then 6mm down to a single socket. As cooker is 2.7kw this is acceptable on a 13a plug top....is this correct?
However now the customer has decided to tell me they're getting a separate electric hob, (this is after 2nd fix) and walls plastered. The info I have on the hob requires a 4mm cable supported by a minimum 32a fuse as the hob is 6500w. How can I do this??
Any help appreciated.
