A
arnoldlayne
Hello all,
I have changed the cable on my Smeg SUK91MFA cooker as the old one was damaged.
The cable terminates into a standard 13A plug and had been fine for years. I replaced the cable like for like and replaced the original plug back on. I wired the cooker end of the cable L-N-E from left to right as I am sure(?) it was wired originally. Plugged the cooker in and it blew the plug fuse and flicked the corresponding MCB. I replaced the fuse, put the original cable back on to rule out the new cable being at fault, but same happened again.
Again I put on the new cable, replaced the fuse and plugged it into the socket with the socket switch being OFF, but it blew the fuse again!
I have replaced the socket thinking this was the source of the problem, replaced the fuse again and same thing happened - plug fuse blown and MCB flicked off.
The only options now are-
1. Faulty cooker - but it was fine prior to replacing the cable
2. I have connected the cable to the cooker incorerectly, but I'm sure(?) that I have connected it the same as it was.
Any ideas please?
Cheers
Any ideas please?
Cheers
