Stever_777
Hi guys, ive just run in a new circuit for a 11,5kW cooker with 6mm T & E which has a gas hob.
Q. Can I use normal grey 6mm T&E from the cooker to the outlet plate or does it need to be heat resistant cable, cause I cant find any heat resistant cable that size in the TLC catalouge?
