Cooker Disconnection Time | on ElectriciansForums
Discuss Cooker Disconnection Time in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
downhilldave100
Cooker 30A I assume the disconnection time is 0.4 seconds, even though the outlet does not have a socket.
Only circuits for distribution above 32A are 5 sec.
Ta
New comer:)
you are right with your original post but you can have domestic circuits that are over 32A for example a shower over 8.5Kw would require a 40A MCB/ fuse but like i said your op is correct
Reply to Cooker Disconnection Time in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
The gas hob might still need to be plugged in for the ignition, but an electric oven should have its own supply. You may need to employ the...
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
