J
jimbobaroobob
Hello there
I need to move an existing combined cooker switch/ 13 A socket in a new kitchen, as the hob will be directly below the existing location.
There is not enough 6mm cable to allow me to move it around 50cm to the left of existing position.
To avoid replacing the whole 6mm cable, one thought was to chase the 6mm cable up the wall, re-route it to the left and place a 45A DP isolation switch for the cooker inside a wall cabinet above the left hand work top. A shorter run of 6mm cable can then run from the switch out the back of the cupboard, channelled inside the wall to the cooker connection unit below the hob.
I know the rule about not attaching to kitchen 'furniture', but as the cabinets will be fixed mounted units I am not sure if this strictly applies.
I note a reply to an old previous question:
'Not forgetting that the switch/Isolator should be a minimum of 300mm/30cm/12" what ever you understand? from the edge of the cooker and NOT above the cooker! And the cooker outlet or socket? (depending on loading of cooker) should NOT be installed in the Kitchen "cupboard" Or in the adjacent cupboard!! but on or in the wall, which may mean drilling a 75mm whole in back of cupboard to pass 13amp plug top through socket, etc etc'
Many thanks
Many thanks
