Cooker hood fan stopped working? | on ElectriciansForums
Discuss Cooker hood fan stopped working? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Hello all.
My cooker hood fan has stopped working and its not something I attempt to fix with customers but I thought Id have a look at my own.
The lights work. It has 240v into the terminal block. 240v from switches back to the terminal block. Then the 3 lives (3 varying speeds) disappear into the motor, 2 others come back from the motor and go into a capacitor. So Im guessing the problem is with the motor or capacitor. Which us most likely? How do I test these?
Cheers. :)
[ElectriciansForums.net] Cooker hood fan stopped working?
Hello all.
Cheers. :)
Ha ha - Probably not the best answer but it worked. I got called out to a customer with a fan not working but lamps etc were. I used a small screwdriver to give the fins of the fan a nudge and tried again and it spun and they never had a problem again.
If its a crap motor, its likely that grease will get in and cause issues, sticking etc. It may only come to light if the fan has not been run for a period of time and the gloop has set hard causing the fan to stick.
Anyway, as I said, not a technical answer but sometimes, the hammer is the best tool in your toolbox
They were working when I left, that's all I'll say :rolleyes: .
Had one where one of the internal conductors had popped out of the terminal, had to use a screwdriver and all.
Reply to Cooker hood fan stopped working? in the UK Electrical Forum area at ElectriciansForums.net
I have a Bosch DKE995EGB cooker hood that has stopped working completely - no lights or fan. I've confirmed power to the control module and...
Hello, Last year my 30 year old Static Pase convertor stopped working, the 3 phase motor is 0.55KW / 0.74HP and drives a small lathe. When I...
