Cooker hood supply | on ElectriciansForums
Discuss Cooker hood supply in the UK Electrical Forum area at ElectriciansForums.net
Rappid
Wickford, Essex
A kitchen fitter friend is seeking advice before he approaches the company.
He turned off the kitchen ring to install a cooker hood and found the supply was still live, he found the supply was taken from the bedroom ring. He spoken to the electrician briefly and the electrician said it was ok to do but he's not happy about the cooker hood being fed from the bderoom ring and wants it changed.
My thoughts on this is that it's not ideal and I would run the cooker hood from the kitchen ring but as long as it has a FCU, the CU is correctly labelled and certificate states the cooker hood is fed from the bedroom ring MCB, I would let it go.
What are your thoughts on this and is there anything in the regs saying that it cannot be done this way?
Thanks.
Reply to Cooker hood supply in the UK Electrical Forum area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
