cooker keeps tripping rcbo as soon as you switch it on | on ElectriciansForums
Discuss cooker keeps tripping rcbo as soon as you switch it on in the UK Electrical Forum area at ElectriciansForums.net
R
rusty_welder
hi people not sure if this is the right place or even the right site to be looking for help but have some problems with my cooker keep tripping the rcbo.
it will reset when the wall switch is off but as soon as you switch it on the rcbo trips, I thought that the cooker had snuffed it so got a new one and wired it in....same problem.
if I disconnect both cookers from their cables the trip resets, I have put a voltage tester on and all seems ok in till I connect cookers back to the cables, my electricians away for a few weeks and it's really bugging me,
any help would be appreciated, if I'm in the wrong place please let me know
Sounds like a faulty heating element on the cooker
Had one myself last month
cheees will look for a electrician tomorrow, but strange the old and new cooker does it, have done loads of checks and cant find anything, taken all cables out of sockets and cooker and put it all back together still no joy, was hoping it was something simple lol
can you get to the cable feeding the cooker ,and replace from the cooker switch .
or is tiled !
its tied from above the work top then underneath we have another box that the cooker cable connects into if you disconnect the cooker from its cable the rcbo resets but if the cooker is connected to it then it won't reset, but this happens with new and did happen with the old aswel
Reply to cooker keeps tripping rcbo as soon as you switch it on in the UK Electrical Forum area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
