cooker keeps tripping rcbo as soon as you switch it on | Page 2 | on ElectriciansForums
Discuss cooker keeps tripping rcbo as soon as you switch it on in the UK Electrical Forum area at ElectriciansForums.net
R
rusty_welder
hi people not sure if this is the right place or even the right site to be looking for help but have some problems with my cooker keep tripping the rcbo.
it will reset when the wall switch is off but as soon as you switch it on the rcbo trips, I thought that the cooker had snuffed it so got a new one and wired it in....same problem.
if I disconnect both cookers from their cables the trip resets, I have put a voltage tester on and all seems ok in till I connect cookers back to the cables, my electricians away for a few weeks and it's really bugging me,
any help would be appreciated, if I'm in the wrong place please let me know
I had one not long ago that was causing an RCBO to trip and immediately thought it must be the element on its way out. Earth leakage clamp picked up decent leakage. When I IR checked the circuit I found the cooker DP switch to be causing it.
you call 3 years old???? ours is a 20 year old double oven jobby, has been used almost every day, and to date has had 1 new 15watt bulb and last year the horrendous cost of ÂŁ30 for a new element.
I have replaced the cooker switch on the wall for a new one, not sure about earth leackage, think I will get an electrician in
lol not old at all to fair it was a cheap one we bought when we moved in so thought that was what the problem was,
[ElectriciansForums.net] cooker keeps tripping rcbo as soon as you switch it on
second hand was it !
Reply to cooker keeps tripping rcbo as soon as you switch it on in the UK Electrical Forum area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
