cooker keeps tripping rcd | Page 2 | on ElectriciansForums
Discuss cooker keeps tripping rcd in the Australia area at ElectriciansForums.net
B
bluematt1
Hi Im pulling me hair out got a cooker that keeps tripping rcd not the trip it mainly happens once its had fan oven on for a while and when you want to check ya dinner ya open the door and it trips it doesnt have a light on it so it doesnt have a switch on door oven remains running when door open thats if its not tripped.
Its a Range type oven belling only 4 years old Ive had the back off and theres nothing obvious touching the chassis of oven it doesnt matter also if the non fan oven is being used ya can sometimes just lean on it and it trips even if the oven is switched off it does seem more heat related though.
Where oven is between units and mfi guy in my eyes mounted work tops to high the oven does sit on piece off board thats bonded in only 12mm just to make oven sit level with worktops and the feet on oven are course platic threaded rubbish things that screw into the thin bottom of oven and being 100cm wide there does seem to be an element of twist in chassis of cooker.
Im almost tempted to go buy anoter but there about ÂŁ1000 and its only 4years old any views would be appriciated.
buy a microwave ... sorted... next...........
could be any loose connection but particulary around element
Far more fun with a camp fire , did you here about the guy who used his BBQ in the house because it rained yes you guessed ended up with no house the numpty
Telextric is right very difficult to locate a low resistance insulation fault with a multimeter , you do need an insulation tester ,and with these you need to be carefull you dont blow up any sensitive electronics in the appliance . it could anything from a stat to an element , without the proper test equipment may be an impossibility to find
Reply to cooker keeps tripping rcd in the Australia area at ElectriciansForums.net
