E
ed-ectrician
Hello there,
You lot have always been helpful in the past and generally not too condescending so I'm going to ask what I feel could be seen as a dumb question (the dumbest being not asking it!)
I went to do an inspection on a kitchen the other day and the spark that had done the work had a kitchen ring on a 32 amp breaker. All good, then he put the cooker on a 32a ring circuit of its own, now my guess on this is that it is not OK becasue the idea of a ring is that the load is distributed on the first and second halves of the ring. With one appliance on the ring this isn't the case so doing a cooker on a 32a ring circuit of it's own with 2.5mm twin and earth cable is not right because the cooker will draw all its current from the "half" of the ring that is the least resistance right? So it's like basically putting a cooker on a 2.5mm 32a radial which is not ok.
The bloke I spoke to said the electrician who did it didnt have 4 or 6mm cable so did it this way. Often the case!!
Am I right here? Missing something?!
Ed
Ed
