Cooker on ring main | on ElectriciansForums
Discuss Cooker on ring main in the UK Electrical Forum area at ElectriciansForums.net
Ive just looked at a job where the double oven is fed from the ring main with no isolator. The rating is 4.2 kw which would draw 18 odd amps. There is no circuit on the board for a cooker. Im not sure wether it would be acceptable to fit an isolator or would it be best to put in a sole circuit for it.
Don't have my BS 7671 to hand, I believe it is in Appendix 15, a recommendation that appliances over 2KW should be on a separate circuit.
It might be my house then, there is a 4 KW oven on my kitchen ring in my house, been like it for 18 years now, totally against the norm but it works lol
Could draw, diversity? that would be the best idea yes
Cheers Pete. just run off mt feet and not had time to look at the regs properly. I found that in the Appendix as you said and have explained this to the customer now. :)
"just run off mt(e) feet and not had time to look at the regs properly" Uhhhhh????? Say no more
Reply to Cooker on ring main in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
Thanks for all your input guys. It seems to be that it’s down to personal preference on the best thing to do/if it’s appropriate. In my head I...
