Cooker outlet, no room + gas ignition | on ElectriciansForums
Discuss Cooker outlet, no room + gas ignition in the UK Electrical Forum area at ElectriciansForums.net
Midlands
Hi all
New build house
Cookers they re supplying dont have room at the backs to allow for the outlet, so for now we are putting 6.0mm out the side cupboard to dual socket then from dual socket to cooker outlet,socket is for plug for gas hob, outlet for cooker
reason for using a dual is for room for the 6.0mm even though we are only using one for the ignition
another problem is we only have a 300mm cupboard for these to go into next to the cooker and its awkward to do
could do with some solutions pls
i have noticed that there is about 12inches of room below the cooker but if we put socket and outlet there the cable for the gas ignition isn't long enough to reach the bottom (was thinking of putting a dual click cooker outlet on its side feeding cooker then socket),gggrrr
any ideas lads
cheers
grand
Yep flipping kitchen designers, quite often end up putting cooker outlet in adjacent (or not so adjacent) cupboard.
Cant see anything wrong with running 2.5mm to single socket (for gas ignitor) from cooker outlet (32amp supply).
Edit; although I tend to spur off RFC for such (gas ignitor)
if it's over 2kw needs its own circuit
No it does not. This comes from Appendix 15 of the bible and that is titled "informative".
The 2KW malarky is just GUIDANCE
its to help the hard of thinking when looking at possible circuit designs.
If the 2KW was a regulation then most domestic appliances would not come with plugs on them, they would have to be hard-wired to connection points around the house.
Your right it is just guidance as is almost every word in the book , but yeah i get you point . I just MISSREAD and thought that the op had changed his mind and was going to plug into the ring main instead(his choice only guidance) .
I know others have already stated/suggested this; for the cooker, I'd install (from the cooker switch) a cooker outlet in adjacent cupboard, mounted surface in the cupboard. For the hob ignitor, I would install a spur socket (spurred off or part of RFC if possible) again mounted surface in adjacent. I would tend to do this on a refurb of a kitchen, and certainly in the case of a new build, where you have a blank canvas.
If for some reason, this is not achievable (and I can't see why not, in the case of a new build), you might have to feed the hob ignitor socket from the cooker outlet, Click do a two gang cooker outlet plate, if space is tight.
Hi Guys,
Well come to forum site.We have noticed that there is about 12inches of room below the cooker. But if we put socket and outlet there the cable for the gas ignition isn't long enough to reach the bottom side (we thinking of putting a dual click cooker outlet on its side feeding cooker then socket).
Thanks.................
Reply to Cooker outlet, no room + gas ignition in the UK Electrical Forum area at ElectriciansForums.net
All socket outlets up to and including 32A (which are commercial, not domestic) are required to be 30mA RCD protected. By the sounds of it you...
