Cooker switch and gas pipe electric shock, aahhhh help? | Page 2 | on ElectriciansForums
Discuss Cooker switch and gas pipe electric shock, aahhhh help? in the DIY Electrical Advice area at ElectriciansForums.net
This has to be a wind up. One of the most incredibly stupid things I've heard. Don't be tight when your putting peoples lives at risk and call an electrician.
I have heard of a spark (no names no pack drill) who, when surprised by a belt, said "that can't be ÂŁ&@ing right!" and touched it again :)
Obviously to narrow the problem down I bought new 45a 2 gang cooker socket
That's probably the least obvious thing to try (other than touching it a second time)
Any suggestions would be very much appreciated
I suggest your installation has at least two dangerous faults and needs fully testing by a competent person
John has hit the nail on the head with his comments.
You've most likely got more than one fault plus what you're doing is downright dangerous which is the reason I'm closing this thread.
You need to get a competent electrician with the appropriate test equipment to help you find the problems. Please don't continue, either you or another user of the electrical installation is likely to get injured.
Reply to Cooker switch and gas pipe electric shock, aahhhh help? in the DIY Electrical Advice area at ElectriciansForums.net
T
The gas hob might still need to be plugged in for the ignition, but an electric oven should have its own supply. You may need to employ the...
