Hi Guys probably a really simple method,
but when you install a cooker switch, it is normally to the left/ right of the cooker, so do you guys put the cooker connection unit or a socket, directly below the switch in a cupboard, or do you put it behind the cooker?
If behind the cooker do you go back up the wall with the cable across and directly down behind the cooker?
Or is there something I am not thinking off to keep within the permitted wiring zones.
Craig
Craig
