Cooktop Replacement: Can I Cut Band on G/W Lines? | on ElectriciansForums
Discuss Cooktop Replacement: Can I Cut Band on G/W Lines? in the UK Electrical Forum area at ElectriciansForums.net
Mike-R
Gainesville, VA
Replacing GE cooktop with newer model, GE PP9830, house supply is 4 wire and two 35amp joined breakers. However, Green and White wires on unit are banded together at tip. Was going to just cut band off, but rating plate clearly says USE ON 3 WIRE ONLY. Manual page 24 says 3 wire OR to 240V with separate ground. Can I cut the band and wire to B/R/W/G 4 wire?
  • [ElectriciansForums.net] Cooktop Replacement: Can I Cut Band on G/W Lines?
You need 4 wire which is 2 hots 1 neutral and 1 equipment ground
My concern is why would GE put 3 wire only on rating plate? Is there something internal, beyond the obvious band on the neutral and ground? If I do the 4 wire connection, should I do a voltage test neutral to ground, should be very little to none?
So, I can't cut off the band joining the green and white wires (see pic) and hook one to each supply line?
You can cut the band off and hook up the 4 wires.
Back in the day they didn’t run but 3 wire for dryers so they was using the neutral for an equipment ground and neutral. Hook it up the way I told you. The 2020 edition of the NEC state that you bring it up to today’s standers if you do anything with your dryer.
If you measure neutral to ground you shouldn’t get no reading
Reply to Cooktop Replacement: Can I Cut Band on G/W Lines? in the UK Electrical Forum area at ElectriciansForums.net
O.P. Pulled the circuit board out to track the wiring. 1- red goes to pump active 2- red goes to first pin of circuit board 3- empty 4- black goes...
