Discuss Coolbox not working from mains in the UK Electrical Forum area at ElectriciansForums.net
dDo you mean it won't cool stuff or it wont turn on as in it's as if there is no electric?Hi
I have a 40L Halfords coolbox which works off 12v cigarette lighter, but won’t work of the 13amp plug.
I have changed the plug fuse, but to no avail. Any ideas?
Cheers
Newbie
Have you checked the output of the mains adapter before connecting it to the cool boxHi
Cheers
Newbie
HidDo you mean it won't cool stuff or it wont turn on as in it's as if there is no electric?
Fuse Blown, bad connection. switch turned off could be anythingHi
The item seems to have no power when connected to the mains
There are two wires which can power the coolbox, one which fits into a cigarette lighter (which works). and the second goes to a normal plug, it’s this one which doesn’t work.Have you checked the output of the mains adapter before connecting it to the cool box
So having got to the electronics it's time to get the multimeter out and do some testing to narrow down the fault, crystal balls are pretty useless for fault finding no matter how often we are askedThere are two wires which can power the coolbox, one which fits into a cigarette lighter (which works). and the second goes to a normal plug, it’s this one which doesn’t work.
[automerge]1596832014[/automerge]
Those seem to be FJP3305-2 which is a 700Vcbo, 4A NPN by Fairchild (whether those are genuine Fairchild is anyone's guess.
Presumably you've tested them and they are shorted all round, or what makes you think they are bad? There is a good chance other parts are bad too. Have you checked the driver, efficiency diodes, feedback network etc? How much experience repairing SMPSU's do you have?
Reply to Coolbox not working from mains in the UK Electrical Forum area at ElectriciansForums.net
