Cordless drill battery charger | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Cordless drill battery charger in the UK Electrical Forum area at ElectriciansForums.net
Mr.C
Hampshire
Might be the wrong forum but here goes. I`ve 2 Parkside drill/drivers 10.8v not had a lot of use but come in handy because they are quite small and do the job. Problem is I`ve lost one of the chargers and the remaining one has given up. I`ve inserted a pic of the circuit board, no sign of any overheating or visible damage any chance someone might have an idea of which component has died or where to start testing, a longshot I know...……..
[ElectriciansForums.net] Cordless drill battery charger
Where the power cable enters on the board is a note saying that for continued fire protection the fuse must be replaced with the same type, a T2AL 250vac. Is that not a glass type fuse, if so I can`t find one……………………..or have I got it wrong ?
I would expect a fuse somewhere, although it may rely on the fuse in the plug top. Maybe they have changed (cost- reduced!) the design at some point but forgotten to amend the text.
Confirm you have 350VDC approx at the large reservoir capacitor. Do this carefully.
I'm sure some people like to learn.
But anyway if the fuse has blown, that is a sign something else is seriously wrong rather than being the fault itself.
Could be an "iffy" fuse I learnt that at Uxbridge Tech back in 1982 or a temporary or intermittent "glitch" that took the "iffy" fuse out in the plug top.
T2AL
T= Traege = slow blow
2A = obvious
L = Low breaking capacity i.e. does not need to be sand filled.
Obviously you can fit a ceramic bodied / sand filled T1AH instead.
Reply to Cordless drill battery charger in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
