corner mount floodlight with pir | on ElectriciansForums
Discuss corner mount floodlight with pir in the UK Electrical Forum area at ElectriciansForums.net
Glasgow
hi all, was wondering if anyone has used a corner mount floodlight so i can light up 2 areas opposite from each other from the same pir, i know you can install it all separate from each other but want to know if there is a all in one fitting for this, i have saw lights that may work but the are only 3w leds i am looking for something a bit stronger probably atleast 10w
Reply to corner mount floodlight with pir in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
