Correct RCD switch? | on ElectriciansForums
Discuss Correct RCD switch? in the UK Electrical Forum area at ElectriciansForums.net
SSE
The RCD switch in my small consumer unit in my shed is a 25A 30mA RCD. The switch is knackered but I've found an old one I've had from an older board. It's a 40A 30mA though, is it still ok to use this? Although the supply is only 4mm it is protected by a 32A MCB in the domestic mains board. The CU in the shed only has two circuits, a 20A for two sockets & 6A for a few lights.
Reply to Correct RCD switch? in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
