Correct wiring of RCCB? | on ElectriciansForums
Discuss Correct wiring of RCCB? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Hello all..
I figure its better to ask and be ridiculed than not!
I am about to add a couple of spurs to a ring that is not RCD protected. The neighbour definitely wants them channeled in rather than surface trunking so I have to RCD protect. It is an old Tenby CU with crabtree SB6000 MCB's. I have found a 32A RCCB which fits this board (see below)
[ElectriciansForums.net] Correct wiring of RCCB?
The modern RCBO's are self explanatory with there flying neutral and (sometimes) earth and I am 99.9% certain this is right (diagram below) but I just wanted some reassurance that I take a single 2.5mm[SUP]2 [/SUP]conductor to neutral bar from N Supply, as the RCCB looks different to any of the modern ones.
Thanks..
correct apart from the neutral link needs to be greater than 2.5mm?
Could you explain a little more please? The ring is on a 2.5mm, why would the supply neutral need to be bigger for the RCCB if its just dealing with that one circuit?
Reply to Correct wiring of RCCB? in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
2 3
