Always learnin
Correctly closing off a dead twin and earth cable in a loft.
My old house used to have radial circuits serving night storage heaters. Those radials came from a dedicated consumer unit in the garage which has now been removed and all cables from it are now dead. Each night storage heater was served by a single 2.5mm twin and earth cable. Where possible those cables (or large sections of them) in the loft space have been cut off and removed, but that leaves "ends" where cables cannot be pulled out of walls etc in the loft.
So my question is:
Is there a "correct" way to terminate these old dead cables so that it's obvious to anyone later what they are and that they are dead?
My thoughts are to cut the copper back to the sleeve on both live and negative, make each end of live and negative a different length and fold them back over the outer grey cable sheath. Then with red electricians tape wind it round over everything and mark the outer grey sheath as "Dead" with a date. See pic.
I'm probably going over the top as usual but I want to do it right. Any suggestions are gratefully received. Thank you
So my question is:
- TL;DR
- Correctly closing off a dead twin and earth cable in a loft.
