B
brookster
I have to look at an 11KV/415V transformer with an reported leak due to corrosion - bear in mind I have not seen the transformer but should be at some point tomorrow.
My initial thought on this are if corrosion has set in to this sort of level where leaks are becoming present the best thing to do would be to replace the transformer, any repairs would be temporary at best and would not be advisable in the med-to long term? can anyone tell me if such a repair would be a good course of action it's something I have never seen done.
Also to maintain the site power a generator will need to be installed to be run as a temp measure until works can be completed to replace the 220KVA transformer.
I cannot yet provide any more info on the level of corrosion will update hopefully tomorrow.
