costing for garage instalation | Page 2 | on ElectriciansForums
Discuss costing for garage instalation in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
due to the garage being 30m away, a 30m run of 6mm swa would definitely increase the zs considerably.
and just to be on the safe side i thought an earth rod in the garage would be a better bet.
I can't see that much of a problem, but easily remedied by the use of a 3 core SWA instead of a 2 core...
What would you consider better, ... A TN system of under 0.35 ohms at the origin, or many 10's of ohms that is also possibly unstable?? A no-brainer, if there are no other mitigating circumstances such as water/gas services that needed bonding back to the MET...
Reply to costing for garage instalation in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You cant just "avoid" the use of RCD's for nuisance tripping... it will depend on how the cable is routed. (ie buried less than 50mm) What has...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
