Guest viewing limit reached
Hi, Hoover Washing machine on fast spin tripping fuse box / consumer unit, 3 or 4 times now. Any advice much appreciated. Thanks Stephen.
Is it an rcd tripping?
I found a faulty washing machine where there was a water leak inside the machine during the drain cycle. Small breather pipe inside had separated from the drum.
Reebok,
Reebok,
