spot5050
Hi, I can't get an RCD to switch on at all, even with the main isolator switched off. Is that definitely a faulty RCD or could it be something else?
I have a metal 8-way Cudis CPN consumer unit with two RCDs, one with four MCBs and the other with one MCB. I originally switched the right-hand RCD off to add a new mains socket upstairs. After doing the work I can't turn it back on. I've tried putting all the wiring back to how it was before I added the socket but that RCD still won't switch back on. Then I tried turning the isolator and all the MCB's off but I still can't switch that RCD to the on position.
I'm a new forum member. Any hints greatly appreciated.
- TL;DR
- I can't get an RCD to switch on at all, even with the main isolator switched off. Is that definitely a faulty RCD or could it be something else?
