countinuity readings on fp | on ElectriciansForums
Discuss countinuity readings on fp in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I
ian1511
on fire alarm system wired in fp,should my cpc-cpc continuity readings be lower than L-L,N-N, readings.its 2 core and earth.is the earth 1.5mm like live and neutrals,i would say so.i no earth is tin plated copper,is this why they are lower?
as fire alarms are wired as radials, how are you getting L-L, N-N, E-E ?
ah, in that case i stand corrected. is not the cpc in FP 1.0mm? and should then read higher?
Reply to countinuity readings on fp in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
