OP
Darkwood
Thanks for the detailed response. Would you say that done correctly the wiring should be mostly above the boards then?
There is no correct way Par se' ... every job is different there are a few ways of doing it all with certain pro's and con's and some been financial and some been time as per my previous post - ill not recommend any method unless I see the job .. if you don't relay all the info or even miss a vital point out then we would be giving incorrect advice.
