couple of questions | on ElectriciansForums
Discuss couple of questions in the UK Electrical Forum area at ElectriciansForums.net
sharpe
Hi, i have a coupe of question.
1. What sort of external earth block is used for an external MEB, used to connect the MEC and a sub-mains earth on a TNS system?
https://www.tlc-direct.co.uk/Products/TLEB8.html
Is this what i am looking for or am i barking up the wrong tree. Does it need to be fixed inside an enclosure?
2. Does a switch fuse always have to be rated lower than the main cutout? Or can it be equivalent to the main cutout?
For example on a 60a main cut out, does the switchfuse used to supply the sub-mains have to be 60a or less?
Is this what i am looking for or am i barking up the wrong tree. Does it need to be fixed inside an enclosure That is the correct earth bar. As the Earthing conductor is not a "live" there is no need to put it into an enclosure. If it is you MET you will need to label it as such.
For example on a 60a main cut out, does the switchfuse used to supply the sub-mains have to be 60a or less? Do you know what the BS fuse is inside your main cut out? What is the sub mains feeding? What is your loading on the sub main? There are far too many questions. But it is not good practice normally not to have some discrimination between protection devices.
See red
When the DNO came out to install the 100a double pole isolator, they said that the cutout was 60a like all the supplies round here and it could cope with the sub-mains. In fact the engineer said that the cutout would be able to cope with 80a plus, which was a little confusing.
The sub mains is feeding the garage. The loading in the garage is a 40a 30ma RCCB, with a 6a radial and 32a ring circuit.
Reply to couple of questions in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
