W
wearethepeople
Hi All,
Bit of a change of direction from my recent post, In an old cottage they have a present a 3 phase cut uot supply feeding a single phase meter with one d/b.
A full rewire is needed, they are having a daikin heating system and the Max demand I have worked out is 165A.
I will obviously need to use all three phases however there is only enough room for a single phase d/b in the existing overdoor cupboard.
1. What meter am I to apply for i.e three phase economy 7/10 or normal?
2. Do I run a sub-main for the meter tails to a more suitable position for a three phase board?
3. If so what cable/isolators will I need to protect tails? (they can run under floor or I may be able to get boxing built around steel works?) run about 30m max
4. Do I divide all circuits evenly over all three phases? they are all single phase distribution circuits
Many Thanks
Many Thanks
