CPC continuity reading | on ElectriciansForums
Discuss CPC continuity reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
EddieB
Testing a T&E ring main I had the following results, why would the R2 reading be slightly lower than R1 & Rn
the T&E was quite old and the conductor size of R2 was not 1.5 slightly smaller maybe 1mm, ideas on a postcard please
R1 reading 1.2
Rn reading 1.2
R2 reading 1.1
supplementry bonding maybe, if this is the case what the next course of action? I'd be likely to leave it as it is
As you know, when doing continuity readings the cables should be disconnected from the fuse/MCB so parallel paths is an unlikely explanation unless the RFC has been wired in a conduit which is earthed and therefore still connecting to the bonding. As long as you're sure the readings are correct I'd agree with leaving as is mate
Reply to CPC continuity reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
