CPC/Earth feed to Light Switch Back Box | Page 4 | on ElectriciansForums
Discuss CPC/Earth feed to Light Switch Back Box in the UK Electrical Forum area at ElectriciansForums.net
B
BettyBoop44
Hi
Just a bit of info required , just been checking all over the house checking for a earth feed to light fittings and switches , ( a friend informed yesterday that there friend have more or less sold there house , but an electrcal inspection has come up with no cpc to all the light switches ) .
I have found 3 light switch back boxes that do not have a earth feed to them , now the question is can I fit a plastic box inplace of the metal one that is in there and not need a earth feed to them ! .
All the light fittings have a earth feed to them ! , every circuit in the house is protected by a RCD .
cheers
BB
Hi
Thanks for your reply , is there a need to check the Zs when there is a RCD in the circuit ! .
BB
Yes, you need to meet the Zs requirements of the over current protective device protecting the circuit. Using the RCD for fault protection is a last resort if you can't meet the Zs requirements of said device, but in my opinion this should only be considered if you have a TT supply.
Hi
You must put this label on the consumer unit with the circuit details!
[ElectriciansForums.net] CPC/Earth feed to Light Switch Back Box
To be fair it might just make someone think twice before fitting metal gear. I know it's unlikely, but even if it makes the difference a couple of times it's better than nothing.
Which regulation is that then?
If the customer doesn't want the work done then walk away from the job, simples.
It's not a regulation, as has already been stated. It's from a best practice guide, and it is a reasonable option where it is not practical/affordable to rewire the lighting circuit.
How is it reasonable? A sticker on the CU does nothing to improve safety.
I'd say that's nonsense, in those circumstances if it prevents someone who doesn't know any better from installing a metal fitting which could become live then it certainly has done something to improve safety ! Just because something isn't stated in black and white in the regs doesn't automatically make it a bad idea.
Reply to CPC/Earth feed to Light Switch Back Box in the UK Electrical Forum area at ElectriciansForums.net
It's unlikely tht a small domestic garden pump and a single lamp will come anywhere near close to overloading even the smallest (3A) fused spur...
