CPC used as interconnect on smoke detectors | Page 3 | on ElectriciansForums
Discuss CPC used as interconnect on smoke detectors in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Where have you taken the above info from? Do you understand that 10 yr battery, radio linked will meet the revised Regs (ie not hard wired & radio linked)?
Are you 100% sure about the 10 year battery bit?
Yes, I do understand that Polo1...but although the scottish government have agreed that 10 year battery , radio interlinked will be allowed (and rightly so) it is not law yet. I have installed stuff where the first detector is mains and 10 year battery back-up, with radio interlink, the others are 10 year battery only, with radio interlink. In a small flat it makes sense as you can hear any one of them from anywhere in the flat. My question was whether there might be confusion if some T+E were present...in wired, interlinked installations.
I presume you meant ie not hard wired and radio linked only, and not mains powered at any point. That is certainly the outcome of the consultation, imho.
Murdoch, yes...the whole point about the consultation, on this matter anyway, was whether modern tech has brought us to a place where 10 year Lithium battery powered detectors can be used and relied upon. I have the government response on file somewhere, and will try to find it and send you a link. In essence, in Scotland you will be able to use 10 year battery modules, radio interlinked. It's a good step, because landlords will see it is cheaper than the old regs, so will be more likely to comply.
No I’m not M, that’s why I posed the question.
The Scottish Gov recently announced that the standards which currently apply in new build and private rented (mains supplied and interlinked smokes in the main living area, hall and heat in kitchen) are to be applied to existing owned and public sector/HA property. The announcement made reference to detectors being no more than 10 yrs old but otherwise was light on detail about the spec and how the change is to be implemented.
Their review was prompted by the Grenfell Tower fire.
Hi - I understand that BS5839 already permits radio linking of mains powered alarms. There are a few conditions and reading the instructions from Aico on their Ei100MRF radio units, they meet those requirements when properly installed and commissioned.
Pirate,
Can you tell me exactly where you have read that 10yr battery only radio interlinked detectors will be acceptable when the Scottish legislation is changed?
Tia
“The following changes to this standard, all supported by the responses to the consultation, are also proposed:
  • to allow specified types of sealed long-life battery alarms as well as mains-wired alarms - reflecting the availability of appropriate technology and will encourage compliance;
  • to specify a maximum age of ten years for alarms; and
  • to require carbon monoxide detectors in all homes.”
The above taken from the Scottish Gov web site. Have to say I’m really surprised on the battery only detectors. It also says “proposed”, so I wonder if it will make the final cut.
If the interconnection cable is elv band 1 and a 3core is installed between heads using a core as the interlink isnt this aggainst reg 528.1 (segregation of band 1& band 2 cables)
No it's covered by 528.1 (ii)
Quoted from the thread I linked at the start:
Either way if it is 230v AC or a 9v DC signal..
The conductor it travels down should be insulated along its length as either
a) if at 230v it is a live part and must be insulated or out of reach etc... 416.x.x
b) if at 9v (or similar) it is mixed voltages in the same cable and conductors should be insulated to the level of the highest voltage present! 528.1 (ii)
Reply to CPC used as interconnect on smoke detectors in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
