Crabtree RCCB 80A 30mA | Page 2 | on ElectriciansForums
Discuss Crabtree RCCB 80A 30mA in the UK Electrical Forum area at ElectriciansForums.net
R
RmBo_0
Hi,
I've just been to a job where the main switch rccb keeps tripping during the night. Haven't had chance to do continuity / IR tests yet as the consumer unit was in a corner cupboard with a revolving rack. So I just did an rcd test which tripped on x1/2 so I started switching the mcbs off one by one and re-testing. Till I got to a circuit that was a 16a radial socket into the loft with lights, CCTV, Ariel booster a bedroom socket and a shower pump all off an extension cable. The booster, socket and pump all being wired into a 13a plug I assumed that could be the problem. I unplugged it all and did the rcd test again and it tripped again at x1/2 but not at 0c but at 180c so i re-tested again and it didn't trip till it got to x1. It did this a couple of times then started tripping at at x1/2 again.
Could this be my tester giving inaccurate readings? or should I just wait till I've done the dead tests and see what problems that brings up. Any help would be appreciated.
Reply to Crabtree RCCB 80A 30mA in the UK Electrical Forum area at ElectriciansForums.net
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
