Crabtree RCCB and ZS testing | Page 2 | on ElectriciansForums
Discuss Crabtree RCCB and ZS testing in the UK Electrical Forum area at ElectriciansForums.net
Birmingham
Hello All,
After a bit of help regards ZS testing on a Crabtree Starbreaker board.
Have replaced 2 lengths of dado trunking in our office block at work and the measured ZS is coming out much higher than the calculated value.
Section 1 - calculated 0.5 ohms, measured 1.92 ohms.
Section 2 - calculated 0.42 ohms, measured 1.68 ohms.
I am convinced it's the RCD causing the higher readings so wanted to check ZS on incoming and outgoing terminals and compare the 2 but as it's Starbreaker with the internal busbar, there are no line terminals to test on. Is there any way I can test this or will I just have to rely on the calculated readings?
I have checked circuits supplied from the non RCD side of the board and the measured and calculated values are equal.
Sorry if it's a daft question but I haven't done a great deal of testing on domestic boards (we are factory based and all our stuff is Schneider or Red Spot 3 phase) and this is the first Crabtree board I have come across.
Thanks and ATB
Chris
I know this is a really old thread, but to correct something for future searches, the Di-Log can in fact do a high current test, is it just stupidly obscure. Basically setting the tester to L-N makes it do a high current test. Join N and Earth together, either use both probes on earth conductor under test or join the leads together.
Di-Log themselves published this:
[ElectriciansForums.net] Crabtree RCCB and ZS testing
Reply to Crabtree RCCB and ZS testing in the UK Electrical Forum area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
