Cracked meter box | on ElectriciansForums
Discuss Cracked meter box in the Australia area at ElectriciansForums.net
H
highspark
Doing a rewire and when taking lights down in cloak room pendant dropped and smashed into meter leaving a big crack in the top of the meter box. Customer asking if he should contact Dno. What do you think lads leave it or get Dno out? Problem is I've pulled fuse and fitted new tails in meter. What to do?
you have accidentally damaged the DNO meter... ring them tell them they will send some one out and either repair it or says its ok...!! accidents happen! if you leave it and some thing happens the poo will fire your direction
Reply to Cracked meter box in the Australia area at ElectriciansForums.net
yeah so it looks like an old off peak heating circuit to what would have been storage heaters my preference is to remove them completely from the...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
