R
rantoftheday
whats the easiest way to use crampets for 25mm conduit into quite hard brick?
thanks in advance
thanks in advance
Discuss crampets in the Electrical Tools and Products area at ElectriciansForums.net
thanks in advance
Crampet or crumpet ?What are these cruampets? I have never come across them. How are they used?
:iagree:Pilot hole/Rawlplug, once you've drilled the hole, might as well use a saddle for a neater job.
Probably the oldest form of pipe fixing.
Very common on lead pipe.
Big hammer, and smack them in, then stand back and wish you'd used saddles.
Mainly used when conduit is concealed after.
Crampet - QVS Electrical Supplies | Electrical Wholesaler
crampet.......
crumpet.......
oops......
You lot have never lived until you've banged in a crampet .
Reply to crampets in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
