CRB/dbs check | on ElectriciansForums
Discuss CRB/dbs check in the UK Electrical Forum area at ElectriciansForums.net
USA
where do you guys get yours done?
ive found a place or two online.
is there any benerfit to getting more than the basic?
Ours are through disclosure Scotland, as for opting for an enhanced version etc I think you need to ask your employer what it is they require (as is what type of security checks they want)
Even then you're likely to be rechecked if you join a firm or go on x job as per the nature of the work
true, we get work in prisons from time to time, the guys that used to do it have left
An enhanced CRB check has to be done by your employer , I had it done 3 times by an employer over a 3 year period as I was working in banking fortresses , however if your working through an Agency they may want to make you pay for it.....
I work in HMP's I am being hassled to do 4 jobs for them now, one in each of the local prisons.
I have no CRB checks done, my company cannot do them on me as it has to be done by an independent organisation, as I am a 1 person Ltd. Co. then that is out.
HMPS did the check on me before I worked there the first time, I believe, and they just keep letting me in now!
I had to provide enhanced information about myself a few weeks before the first planned job, a few years ago, and it's never been an issue since.
The, major reason I have a JIB card is that IF I need a CRB done, it can be done through them.
As you can't do it on yourself, I would leave it up to your employer to sort with HMPS.
thats the reason i asked because you can do it yourself, my mother does them daily at work in council
Crikey Trev..... Innocent until proven guilty. At least a convict would not get one.
Hey don't get me wrong TJ, I firmly believe in that mate. The point is though that these things are held up by the powers that be as some sort of definitive proof when they are nothing of the sort.
Let's not forget why they were introduced, they were another sticking plaster over a gaping wound after the Beverly Allitt case where a criminally unbalanced individual was working with children and hurting them to draw attention to herself.
They wouldn't have stopped her then an they wouldn't stop her now because she hadn't been convicted of anything at the time.
Reply to CRB/dbs check in the UK Electrical Forum area at ElectriciansForums.net
Interesting item you have there. This blog might be worth a read https://sllipblog.wordpress.com/2014/04/29/its-now-00-28am-and-i-need-my-bed/...
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
