Crimping or Soldering Flex cable | Page 2 | on ElectriciansForums
Discuss Crimping or Soldering Flex cable in the UK Electrical Forum area at ElectriciansForums.net
W
wayne305
Evening all, hoping someone can clear something up for me.
I was told today that all stranded flex cables need to be pin crimped or soldered before connections are made, eg, for a towel rail or small wall heater etc. He said the regs were altered in April 2012?
This is the first I've heard of this and just want to know if anyone can confirm this is true?
Cheers
Wayne
Smalls, so .5 > 6mm
they do that size
[ElectriciansForums.net] Crimping or Soldering Flex cable
even rrp is cheap
I use the 97-72-180 as they have chunkier handles which means I can still use them even when the arthritis plays up. (28 and I've already got arthritis in both hands that means I cant grip thin handled tools like those pictured above!)
I've had a disagreement with a bloke at work over crimping tool types
He says you should always use the ratchet type versus pliers and they should be the type that form a square crimp
rather than a round crimp
I'm of the opinion that unless calibrated crimps are required then either type is fine to use as long as the user is confident that it's made off correctly
I don't think the shape matters too much when using the smaller sizes a square terminal will compress a round shape ferrule somewhat anyway, but if the wire is a larger size into a closely matched terminal ie 16mm into a 16mm terminal I'd use the crimper shape dictated by the terminal.
Any thoughts opinions on this?
i disagree.
with ferrules you can feel woth pliers if there tight.
with ratchet crimps there is no feedback at all, i know for a fact as i went around with pliers recrimping them because the previous guy thought they had crimped but they loosend that much they didnt crimp properly
i disagree.
Ratchets everytime mate especially when your doing panels or lots of ends at once, no good just assuming they are tight always best to check, plus I got mine for freeeeeeeeee lol
I cannot see a problem with the plier type for most types of install
I know it's made off properly yet I'm always in doubt about the ratchet type due to the reasons I posted earlier
I own 2 ratchet crimpers both give the square shape and 2 of the plier type (round) I think the pliers give a better mechanical connection , never been able to pull one off easily but have managed to do so on ones done via ratchet crimpers
Just my opinion.
I agree with you. The reason being a through crimp is designed to hold two cables together, a ring crimp etc is designed to hold a cable onto a separate shape on the end of the cable to terminate it with so they need to offer a degree of tensile strength otherwise the cable will come off the crimp, but a ferrule simply goes around the stripped end of the cable, which goes right to the end of the connection; if it failed or weren't there at all the screw would still be tightening onto the core of the cable.
Reply to Crimping or Soldering Flex cable in the UK Electrical Forum area at ElectriciansForums.net
