i do see what your saying but there must countless people out there that just have a quick look under the sink, quick look in the gas meter and then crack on with everything, the previous firms ive worked for were always about time on the job and would expect me to know in a matter of seconds what the bonding was like.
Just because other people have a quick look it doesn't make it right or good practice.Set your own standards
they would not of expected me to get the wander lead out and check for continuity of these bonding conductors.
Why not? It's the simplest method of verifying continuity of bonding conductors.
again im not disagreeing im just saying there's gotta be a little bit of give n take, the wall light installation is no unsafer now than what it was before, and come next weekend it will be 1000 times better, you cant tell what state stuff is in till you physically start testing it as i found with the earth rod, which doesnt comply with the 200 ohm limit and ive never tested Ze or Ra before doing some work (unless im just a crap sparky! lol)
I am not being sarcastic when I state this but you will find no mention of give and take when it comes to electrical installation work. It may sound a bit an@l but by conducting a few simple inspections and or tests before you start work will highlight the difference between a professional electrician and a crap sparky.
i mean whats better: 1. guy does work himself, sorts it out, jobs a good n, no testing done, sorted or
2. spark goes in, disconnects wall lights, tests, finds lots of problems, customer says come back next week n sort it.
I think we both know the answer to this
yes the bonding wasnt up to scratch, but neither was the main earth, the earth rod, and i suspect im gonna get some funny results when doing EIC nex weekend aswell.
but it will all be made good and to the 17th. where as it wouldnt if i hadnt of gone in
If the main earth and rod are not up to scratch and you know it beforehand then you defintly should not start work before this is rectified.
If on the other these problems are identified during testing then I agree there was not a lot that could have been done prior to the work being undertaken
i know technically you shouldn do work till main equip bonds are ok,
So why are you then?
but in summary you cant always tell and often find there not up to scratch when they look like they are.
Yes you can. By visual inpection and/or a continuity test.
i did explain to customer that if i found anything untoward i would have to put it right, which i did and i am doing next week
This is the right approach and you are not leaving yourself open to further problems later on.
I realise that this post may come across as confrontational but it is not mean't to be.
All I was trying to do was offer advice as to how to avoid certain problems in the future and get your jobs to run more smoothly
My initial approach to any job is always the same.On initial survey of a job ie estimating I always inspect the bonding/ earthing. This way You can immeadiatly point out potential problems to customers. In doing this they are then prepared for extra work as required.You are also then better prepared to carry out the work. It also looks more professional.
We've all been there. Go round to a customer to change a light fitting,simple job blah blah blah. Then you go to fill out a minor works, oh poo no bonding. When you tell the customer there is a chance that they will think you are trying it on for a bit of extra work, after all everyone in the whole building trade is a ripp-off merchant
There are no grey areas in electrical work and as long as you follow regs and procedures to the letter you will not leave yourself open problems later on. Cover your --- at all times.You will also come across as more professional to customers which in turn should generate further work. All IMHO of course.
