CT8775C Thermostat three wire heat only (jumper intact) | on ElectriciansForums
Discuss CT8775C Thermostat three wire heat only (jumper intact) in the DIY Electrical Advice area at ElectriciansForums.net
wndrvr
Wy
Which terminal is used for ground to verify power supply? Thank you
Reply to CT8775C Thermostat three wire heat only (jumper intact) in the DIY Electrical Advice area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
It sounds like there is either something up with the wiring to (or from) that thermostat, or the thermostat itself. If you disconnect all the...
