CU & Bonding again!!! | Page 2 | on ElectriciansForums
Discuss CU & Bonding again!!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
mmmm, that seal looks a tad brittle from here......a freak gust of wind and it looks like it may come off!!!:p
I hear what your saying Lenny :). Just want to make sure it's all kosher as I'll probibly use it for my assesment. Another reason why my 6mm bonds are concerning me!
I may give western power a call and see what the damage is to move the lot next to the CU.
Has anyone come across the "using 6mm bonds" during their assesment?
I asked this question on the voltimums website:-
On a TNS installation in a flat the DB has to be upgraded to a 17th edition unit because the existing unit is damaged but the customer does not want the earthing to the gas and water upgraded from 6mm to 10mm.
Where does the installer stand with regards to this situation
With regard to your question, you may well want to refer to the Electrical Safety Council's Best Practice Guide 6 on replacing a consumer unit. See their website www.esc.org.uk
Generally speaking you must leave the installation in no worse a condition. Where the earth bonding does not comply with current requirements then the competent person should be able to use his knowledge and experience to determine if it is safe for the bonding to continue in service. For a TN-S system the 6mm2 bond may well suffice. If it is a TN-C-S the distributor may require the bond to be 10 mm2
This was answered by Select
Thanks rocker I know you're right, it's just gonna be a blo%dy nightmare. I keep thinking about that ECS comment about the 6mm as aposed to destroying my house to get the 10mm's in.
Thanks again!
Thanks oldtimer, Ze is fine (with 6mm from PME cutout), continuity to gas and water fine also. DNO has supplied a 6mm therefore I would assume 6mm bonding would be adequate. If I was doing this job for someone else, seeing the work that is involved, I would stick with the 6mm and write it on the EIC as a deviasion, however to use it as an assement is another story!
Maybe you're looking at it the wrong way.... if you were to upgrade, would you have to run the bonding the way it's already been run, or would it be doable under floorboards etc?
Reg 544.1.1 I think a lot of people just see the part about 6mm^. The second paragraph clearly states that where PME conditions apply, except for highway power supplies, then the bonding condutor shall be selected in accordance with the neutral condutor of the supply and Table 54.8
That clearly states that 35mm^ or less you need a 10mm^ conductor.
The first paragraph deals with all other systems TN-S, TT, IT which states that bonding condutors can be half the size of the main earthing conductor of the supply, but a minimum of 6mm^. In other words if you had a 10mm^ for any reason, you could not use a 5mm^ if there was such a beast, you would use the minimum of 6mm^
It's a strange reg in many instances as I think it still identifies main supplies of 16mm^ and so the Bonding could be a 8mm^ if that existed. Instead of just saying a blanket 10mm^ in the minimum, it says 6mm^ is for those 16mm^ supplies
Nobody just says yes or no anymore :mad:
I see. So it is a minimum of 10mm then and there's no way around it!!! As widdler say's, no matter who you ask (people who make the rules) no one will give you a stright answer.
If it was the case that there is no way these bonds could be changed, it would be crazy to stop someone having a safer and upto date board with RCD's and MCB's just because the bonding cannot be changed.
As you konw the regs are not law, and if you want to leave it 6mm^ then that's your call as the designer. The trouble with that is
a) As it's your assement the assesor will pull you on it as it's not to the Regs
b) god forbid if anything happened and your in a court of law you have to argue why you decided that 6mm^ was satisfactory, so it's not worth it do as the Regs say and your covered.
The problem is and you know, there is really no such thing as no way to do something, there is always a way, just maybe be difficult or cause problems, unfortunately the regs don't take into account that the customer or you don't want a 10mm^ cable clipped surface all over the place.
I totally agree I submitted this question along with "can I use conduit as an earth if upgrading a fuseboard" as I live in Edinburgh and I am starting to get enquiries from potential customers who want a "safety board" but do not want to rip up their house ie laminated floors
etc when they have 6mm cables to the gas and water yes I know the regs says 10mm but I am hearing from people in the trade and know who say if TNS and the 6mm is in good nick ok but if TNCS then you must upgrade to 10mm. Thing is I have already lost 2 jobs because " I only wanted a new board" reply
Reply to CU & Bonding again!!! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
