I have been asked to do a rewire and plan to use it as my elecsa assessment the only issue i have is that the owner wants the CU in the same place as the old one that is over a doorway in a open porch.
The issues i see are,
That unless you are 6' plus you will need to stand on something to access the switches.
Althrough it is protected from rain it is exposed to the outdoor cold temperature and spiders etc.
What are you thoughts is this acceptable to locate the CU in the porch.
